Neon underbody kit
CrazyLilMike
Neon underbody kit
Where can i get a blue neon underbody kit? I have wanted 1 for a while but have had all my $ in numerous mw-3 projects... Also how much would it cost and how much would it cost to install? thanks, mike
Re: Neon underbody kit
go to <A HREF="http://www.jcwhitney.com" TARGET=_blank>www.jcwhitney.com</A> or <A HREF="http://www.streetglow.com," TARGET=_blank>www.streetglow.com,</A> they run about $150 but they are a tight addition to any car.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
HeatherChellette
Here's another option that might save you a little cash. Try E-Bay or a similar site. <A HREF="http://search.ebay.com/search/search.dl ... etaEndSort" TARGET=_blank>http://search.ebay.com/search/search.dl ... EndSort</A> <BR> Just in case that link doesn't work, just go to <A HREF="http://www.ebay.com/" TARGET=_blank>http://www.ebay.com/</A> and put "neon underbody kit" in the search box.<BR> Hope that helps you out!<p>[This message has been edited by HeatherChellette (edited July 06, 2001).]
Heather
David Coleman
Moved to the New Appearance forum!<P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
David Coleman
Look on e-bay or yahoo auctions. I found a 4-piece underbody kit thats green. It's sweet. If you buy some lights, you need to buy some side skirts to hide the lights on the side of your car. Good Luck.
white fish
Are they steet legal?<P>------------------<BR>Clear White 2.5L GSR
Guest
depends on state and country laws, i would recommend calling local law place, they can tell you...<P>------------------<BR>-------------------------<BR>1992 Mazda Mx-3 GS<BR>Brilliant Black<BR>1.8L DOHC V-6 5 Speed<BR>-------------------------
Street Glow neons are very bright and are good quality (from what my friends tell me...they have them, so they should know). They come in a lexan case, so they are very hard to break (but not impossible if you high-center on something or rip them off on a speedbump). The key is to put them as far under the car as possible (as far from the road). I have heard many different opinions about if it is legal or not. At least in Texas, from what I understand, it is illegal to have a light other than Red or Amber shining from the rear or sides of your car. I also understand that from the front, you can only have either white or amber lights shining. Now if you had a Red car and wanted Red neon, then I would imagine that you might be able to get away with it with little/no problems. I have also heard that if the police cannot SEE the bulb (without crawling under the car), that it is ok (because it is shining on the ground and not from the front, side, or back). I could be totally wrong on this issue, but that is what I have heard. I think that there are 3 KEY factors to putting neons on your car. Factor 1: Be sure to put an easily accessible on/off switch for the neons so you can flip them off real quick if needed. Factor 2: Use common sense as to when/where you decide to use them. Factor 3: Do the police in that particular area have nothing better to do than to pull you over for having neons? I would say that if a police officer is looking for a reason to pull you over, then the neons would probably do it (wheter they are legal or not). I had green driving lights on the front of my truck (and FrogChick has 4 (2 on each side) green side markers (near her doors) and neither of us have ever been pulled over for them (even when passing within 6 feet of cops at night). I KNOW they could see the green lights because they are so bright (you can't NOT see them). They just dont care because we are not doing anything wrong. Hope this helps.
