Distributor Problems
I recentlty replaced my distributor, after it had gone out. Now my car wont idle. Does anyone know what I might have done wrong, or what I can do to fix it?
cody keith
Re: Distributor Problems
Did u adjust the timing properly? You need to jump ten & ground on the test connector when setting the timing.
91 Eagle Talon Tsi AWD *RIP*
I timed it, and it works better now. It was also problems of a disconnected vaccum tube, from whenm I install the cold air intake.
cody keith
