Need a list of trannies will work with both the K8 and K
Posted: November 10th, 2004, 5:13 pm
by Juans_93_MX3
So far I know the stock K8 Manual transmission will work with both engines. How about others?
Re: Need a list of trannies will work with both the K8 and K
Posted: November 10th, 2004, 5:25 pm
by RoundTop
Well...the tranny from the KLDE/ZE (MX-6), or from the milennia S (FE) AFAIR.
Pretty much K series trannys are interchangeable.
But only diff between the MX-3 and 6 trannies is that the MX-6's one has a slightly lower ratio for 5th gear (so lower RPMs are on the highway...slightly)
Posted: November 10th, 2004, 5:27 pm
by monstar-mx-3
I'm running a DE tranny on my stocker 1.8. No problems runS great!
Posted: November 10th, 2004, 6:08 pm
by papa roached
its a different final drive not 5th, all the gears will be spaced out a bit more and i hear that its only in the 626, not hte MX-6 or Probe
Posted: November 10th, 2004, 6:48 pm
by Gro Harlem
don't go by engine, go by the tranny series.
K-series all used g-series tranny's...so any car with a 5spd tranny w/a K-series engine will work.
the lsd one fits and works, but you have to source the axles too, or make custom ones
Posted: November 10th, 2004, 7:13 pm
by TsiMiata
Here are the cars that came with manual trannies that will fit the KLZE, KLDE, KFZE, K8 & KJ engines
1993-1997 Ford Probe 2.5 V-6
1993-2002 Mazda 626 V-6
1995-1999 Mazda Millenia 2.5 V-6, The "S" 2.3 liter model only came with an auto
1993-1997 Mazda MX-6 2.5 V-6
Not sure wha they came in but the 2.0 KFZE tranny will work also.
Posted: November 10th, 2004, 7:49 pm
by bmwm3guy
The MX6 and 626 use the same tranny with the lower final drive ratio
Posted: November 10th, 2004, 10:18 pm
by Juans_93_MX3
Wait a minute... Someone told me the Ford Probe 2.5L tranny dosent work with a K8...
Is that true?
Posted: November 10th, 2004, 11:45 pm
by mxmaz
no that is not true, the 2.5 probe manuel tranny will work
<small>[ November 10, 2004, 10:47 PM: Message edited by: mxmaz ]</small>
Posted: November 11th, 2004, 7:49 am
by Gro Harlem
the probe tranny is actually completely identical to the mx3 tranny. the 626/mx6 ones have taller ratios
Posted: November 15th, 2004, 1:38 pm
by Sean Mandell
i heard that the guts from the 99 escorts will work with the g series tranny and are more reliable for higher hp k series motors.....
Posted: November 15th, 2004, 2:11 pm
by Juans_93_MX3
Is a 99 Escort tranny AWD?
Anyone get a comfirmation on the tranny working on the K series?
