Dead Electronic Speedo On manual trans 92 GS
Silkwyrm
Post by Silkwyrm »
I cant seem to find the speed sensor anyone know where it is? I suspect the guage cluster itself is good, because occasionally it seems to start getting a signal and the needle hops about for a bit. Also I pulled the guage cluster out removed, checked and reconnected all the connectors. So I dont think it would be in those connections so I assume its the connection at the trans or the sensor itself. Does this make sense or am I missing something to check.
Thanks,
Rik
ZEmadman
Re: Dead Electronic Speedo On manual trans 92 GS
Post by ZEmadman »
just got done getting mine "rebuilt" corrosion on the connectors. the VSS (vehicle speed sensor) should be attached to the transmission. right near the opening for filling the tranny w/fluid. good luck finding just that though mazda will sell you the whole wiring harness for 450 bucks but it only cost me labor to have mine redone.
maybe take a trip to the junk yard
<small>[ October 29, 2004, 12:53 AM: Message edited by: ZEmadman ]</small>
mdavis
Post by mdavis »
I believe the speed sensor is above and between the axels...
GS-R SE
Fixin's
Silkwyrm
Post by Silkwyrm »
Thanks guys, I'll have to look again. Sadly there doesn't seem to be any good salvage yards around here with MX-3 parts.
Rik
