5 speed Tranny problem V6
joshcallahan
Im hacing a problem, and im not sure what it is, when i shift into 3rd gear in my car, and hit the gas, the gear pops out, it won't stay in 3rd unless you hold it, if you hold it, it's fine...Otherwise it pops out...Any info will be appreciated...
pelado
Re: 5 speed Tranny problem V6
Only a tranny rebuild will help this.
