wrong engine?
wrong engine?
I'm kind of worried, today i got to take a real good look at my kfze engine i ordered from Osaka. It arrived about a month ago. The serial number is KF 244941. But the cams are stamped k8 101 and k8 1A1. And there is stamps all over the engine that say either k8,kl,or kf. The distributor says kf01 on it among other numbers and the pcv valve also says kfo1 on it. Can anybody tell me for sure what engine i have?
Re: wrong engine?
the k8 101 you could see between the IM, i think that is the cams right? i dont know much about engines
- bmwm3guy
Re: wrong engine?
check on the front block by bending over the fron of the motor and looking for the code that is written on the block... if it says kf something, then it is in fact a kf... i dont know if the cams are the k8 101 or not tho ![Shrug :shrug:](./images/smilies/shrug.gif)
Re: wrong engine?
The part numbers for the K series use K8, KF, KJ and KL letters, but the parts can be used on two or more of the engines. e.g. the KF and KL engines use the same distributor, KF34-18-200A, whereas the K8 and KJ engines use K834-18-200A.
But, as said above, the blocks are unique to the engines, so the letters KF on the block definitely identify a KF (and the same goes for K8, KJ and KL).
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
Re: wrong engine?
You have a KF. Some KF's had K8 heads for some reason. But that's insignificant anyways since I don't think there's any appreciable difference in flow between the two. The bore and stroke is more important in this instance, and you've got a 2.0 liter, not a 2.5 liter. Is that at least what you ordered?
Re: wrong engine?
hmmm you might have the 140hp kfze used mostly in europe (doesnt mean it didnt exist in japan) if you'd like to compare motors i have tons of pictures of mine which i know is the 165 hp (no such thing as a 170hp kfze just sounds better)
link1
link2
link3
link4
link5
link1
link2
link3
link4
link5
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Re: wrong engine?
He says in the first line he ordered the kf
Re: wrong engine?
When I got my KF-ZE it said K8 101 and K8 1A1 on the heads but on the block it said KF. The cams on mine were KF 101 though.
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
- papa roached
Re: wrong engine?
sounds like a KF-DE
Re: wrong engine?
also the engine has external coil distributer and straight neck intake manifold. The lettering K8 101 that i can see by looking between the runners on the IM, would that be the heads or the cams i was looking at. If it was the heads, where would i look for the cams lettering to?
- Custommx3
- Site Administrator
Re: wrong engine?
You probably have the KF-ZE.
Take off the vavle cover
<img src="http://www.barrykclark.com/pix/GS/KFZE/ ... er_off.jpg" alt=" - " />
Look for this number...
<img src="http://www.barrykclark.com/pix/GS/KFZE/ ... label1.jpg" alt=" - " />
Re: wrong engine?
Thanks for the replies. I'll take a look at the cams today.
- Aston Wards
Re: wrong engine?
It'll be a KFZE, the K8 heads on mine spooked me too! don't listen to the dumbasses who've never seen a KFZE before!!
<small>[ September 08, 2004, 03:09 PM: Message edited by: Vicious ]</small>
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
![Image](http://i2.photobucket.com/albums/y20/ViciousZ32/carbanner.jpg)
Re: wrong engine?
to anybody who cares... i popped of the valve cover and it does indeed have kf01 cams
Re: wrong engine?
Check and compare using this site:
And go to Engine Identification link
Hope it helps!!![Smile :)](./images/smilies/icon_smile.gif)
Hope it helps!!
Compact Gladiator
"Do not follow the path, instead; go where there is no path and leave a trail"
WWW.GEOCITIES.COM/NEWFLOW81
