I got the vacuum diagram for the whole car, but it's sketchy when it gets to the EGR as it has four hookups, and have no idea which or the four lines goes to which of the four ports on the EGR control. Also, I don't know which side is the top, and which the bottom.
Anybody got a pic that can give a clear description? Or even a description based on one side having a red dot, and the other another color dot?
Thanks.
EGR hookup pics / explanation?
lakersfan1
pelado
Re: EGR hookup pics / explanation?
lakersfan1
PERFECT! Thanks. I knew I had seen that thread recently, but couldn't find it for some reason. The heat must be getting to me. I didn't even realize that there was that 5th brass nipple there. I was only paying attention to the 4 black nipples. Once I saw a pic of your hookup of the short tube connecting both sides, I figured where the vacuum hose with a red dot went, then I found two hoses tied together that were bent at such an angle to show me which went where. Thanks alot.
