Millenia EGR vacuum hose config
Posted: July 14th, 2004, 3:20 pm
by mdavis
Does anybody know how to hook up the vacuum hoses on the Millinea EGR? I've got no idea. There are 3 unfilled nipples on the solonoids and 1 on the valve itself. There are pics at these links: (If they don't load copy/paste them into a new window.. sorry) Thanks
http://www.mkd.cc/egrvacuum1.jpg
http://www.mkd.cc/egrvacuum2.jpg
Re: Millenia EGR vacuum hose config
Posted: July 14th, 2004, 7:25 pm
by pelado
Make sure those solenoids will work with your wiring harness (if you want to use them).
I would use the EGR solenoids on your MX-3. You did label everything when you took wires/hoses off didn't you?
<small>[ July 14, 2004, 06:29 PM: Message edited by: pelado ]</small>
Posted: July 14th, 2004, 7:36 pm
by pelado
The brass looking fitting goes to the air filter housing. The other fittings, one goes to the intake and the other connects to the EGR valve. I can't remember which does which (blue or red dot). However, the vacuum solenoid will not let air pass through it when disconnected and the vent solenoid will. The vent solenoid is connected to the EGR valve while the vacuum solenoid is connected to the intake. That should be enough info for you to nuke it out.
Posted: July 14th, 2004, 7:39 pm
by pelado
I'm so ashamed, the vent solenoid is the one with the brass nipple.
Posted: July 14th, 2004, 7:55 pm
by perhapsadingo8yerbaby
Took a real man with brass ones to admit that...
Posted: July 14th, 2004, 9:22 pm
by mdavis
Hey thanks. Actually I looked at the MX-3 EGR and figured it out (duh lol) sorry about that. But ya, of coarse I labled it. But the motor's been in for some time so the EGR wiring was the only stuff not hooked up anyways.. But thanks again
