stop the codes!!
DJester187
stop the codes!!
Post by DJester187 »
could someone please tell me how to stop codes 2,5,10,16,24,69 from messing up my engine! I'm stalling out!
Electric Black '93 MX-3 GSR, Curved neck KLZE, KL36 ecu, Outlaw Engineering Thermal Spacers, Custom CAI, Carbon Fiber Invader Style hood, 2.25" straight pipe exhaust, custom muffler, lowered 1.8", and a set of 17" Exel DL-46's. With more to come once I get some $$$....
RobertoCarlos
Re: stop the codes!!
Post by RobertoCarlos »
You have to find out what each code is for and then try and fix it accordingly. I dont know what the codes are but there is a post somewhere on here explaining what each code is. Thats about all I can suggest
IanL
Post by IanL »
In the above order:
Crank Angle Sensor 2
Knock Sensor
Intake Air Thermosensor
EGR Position Sensor
Feedback Sensor (Right Side)
Water Cooling Fan Relay
Can they all be wrong? Maybe its a general electrical fault - check the alternator output.
DJester187
i thought the same thing when i saw all those codes, i do have like 5 or 6 clips for sensors that i have no where to plug them into, any ideas?
mazdubber
Post by mazdubber »
Was it always like that? Try to find any sensors in the general area of the clips locations. Process of elimination.
92 GS
'Stock'... :twisted:
DJester187
believe me there are no mates for the clips, do i need to put my k08 manifold onto this enige so that i can hook up these sensors?!?!
