MSD SCIL INSTALLATION ??????
Need to find instructions to install a external coil and rev limiter on my klze. reason for just siezed up my #4 valves. I hit 9400 rpms in third gear with my new 6 puc ACT race clutch and 9 lb. flywheel from unorthodox with a 75 shot of NOS. my rev limiter has never worked. just looking for some guidance.
1992 MAZDA MX-3 GSR 2.5LTR V-6
2005 SUBARU STI
2004 NISSAN ARMADA
http://www.cardomain.com/id/wkdmx3gsr
http://www.netuners.com
2005 SUBARU STI
2004 NISSAN ARMADA
Re: MSD SCIL INSTALLATION ??????
is that a wet nitrous or dry?
dry
2005 SUBARU STI
2004 NISSAN ARMADA
2005 SUBARU STI
2004 NISSAN ARMADA
here is a "how-to" I created on mx-3quebec.com
http://www.mx-3quebec.com/Forum/viewtopic.php?t=3856
Its in french, but I added many pictures and Jeff "Mazdamaniac" wiring diagrams as well.
May be very convenient since his site is currently down.
Here is the final result :
<img src="http://www.3danimation.ca/2004-02-13/PDRM1092.JPG" alt=" - " />
thanks
2005 SUBARU STI
2004 NISSAN ARMADA
2005 SUBARU STI
2004 NISSAN ARMADA
- papa roached
1: i would kill for that in english
2: notice any gains?
If you have a jspec ecu the rev limiter doesnt kick in until 7800rpm. That would explain why you havent hit it.
The rev limiter isnt your problem. If you blew it up you need more fuel. Your fuel pump may not be keeping up, the injectors might need to be cleaned, you may need a bigger fuel jet.
For that webpage in english go to babelfish.altavista.com there is a web page convertor there.
91 Eagle Talon Tsi AWD *RIP*
i have the diagram to hook msd and external coil up e-mail me chopperpozz@hotmail.com will send it to u!
93 Black KL-DE powered Mx-3.
E-mail - chopperpozz@hotmail.com
