I tried to put the stock strut bar on the klze, but it didn't work, because it would sit right on top of the intake manifold. Than I tried to put it on reverse, so the bar is a bit more to the firewal, it sits very tight on top of the block off plate at the back of the intake manifold but I can actually tie it down without any problem.
My question is, would it do any harm the engine or engine mounts etc... because the engine can't really move alot when I rev the engine.
Thank, Bastian
stock strut bar on the klze with ms8 intake
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
Re: stock strut bar on the klze with ms8 intake
no it will not do anyharm
If it is rubbing it all something will wear through, either the bar or the manifold.
91 Eagle Talon Tsi AWD *RIP*
Thanks for the reply, it is rubbing the strut bar and the part of the intake manifold with the block off plate, it got two pieces where you could put some bolts on, but which you don't need, I'm sure you know what I mean. I Guess it won't rub much, because it's very tight.
Glad it won't do any harm, I guess you can use your stock strut bar with a klze.
Bastian
Bastian
i've been reading that our cars came with stock strut bars, mine doesn't have one though?!
- Custommx3
- Site Administrator
some european cars had them, North american cars did not.
WE used bold to put the bar back a few inches, so it clears the IM no problem
<img src="http://www.nd4spdse.net/bat3.jpg" alt=" - " />
