problemos
- Kokiriwave
problemos
alright...if there is anybody that knows anything aboot this problem (OR SOLUTION!) talk to me.
After driving the car for about 30 minutes, when i come to a complete stop the car stutters. When i look at the RPM meter the needle is playing between the 0 and the line under the one... then it stalls. When i turn it back on it still stutters.. I'm thinking it could be the heat because it happens slower on Cold days (meaning i have to drive longer for the car to act up)
Whats the problem and how do i solve it...
Thanks fellas
Thanks fellas
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
- Kokiriwave
Re: problemos
the car has hit 110k miles and is almost time to get the timing belt replaced..
ANY HELP OR COMMENTS WOULD BE AWESOME.
I want MAZDASPEED!
- SE-Man
Re: problemos
mine acts simular, I have vacume problems.
Nice to see another MXer from WA, where you located?
- mitmaks
Re: problemos
mine started having this not long ago and its only ~74k miles on it
Re: problemos
Yup, I got the same problem here. I haven't really done much about it cause I'm about to do the ZE swap. I did turn up the idle a little, and it helped quite a bit.
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
- Kokiriwave
Re: problemos
looool....now that i know i'm not alone i guess we should all start a club.....looool
Anyone with a solution.!!!!????
ur a washingtoner...I'm up in Seattle.
<small>[ March 22, 2004, 10:24 PM: Message edited by: Kokiriwave ]</small>
I want MAZDASPEED!
Re: problemos
Am I reading it right that the tach needle is jumping from 0-1000rpm very quickly- not in synch with the engine?
91 Eagle Talon Tsi AWD *RIP*
- Kokiriwave
Re: problemos
the needle jumps around in the zeroish area it never reaches the half way point between the 0 and 1....kinda confusing...
I want MAZDASPEED!
- userAttila19
Re: problemos
Guess what... Same problem..
But I would check the large accordian looking hose on your air box for cracks. Mine has a crack and I keep tapping it up with electrical tape and the problem gets much better. It holds the pressure properly when seeled. But when the tape wears and comes off the problem comes back. I'm evetually going to get a cold-air filter..
Hope it helps...
~ATtiLa
Hope it helps...
![Sad Wavey :sadwavey:](./images/smilies/sadwavey.gif)
~ATtiLa
No time to slow down. 1995 MX-3 GS http://www.cardomain.com/memberpage/566272
- SE-Man
Re: problemos
I've already checked mine, But I know for sure mine is a vacume problem
- Kokiriwave
Re: problemos
yup its the accordian hose...u know why...because the last owner of the car broke it...and its wrapped in duck tape...it has to be the problem...anyone know whats the part number or where i can that replaced? junkyard?
I want MAZDASPEED!
- SE-Man
Re: problemos
Holy S**T did you buy the SE that was for sale in auto trader? from some guy who "bought it for his GF, and now wants to sell it?
Best way to fix it (It will be expensive to order from Mazda) is to get 3' PVC pipe, 3' hose connecters, and a cone filter. If you need more info, do a search and their actual directions on this, or just e-mail me.
<small>[ March 26, 2004, 07:15 PM: Message edited by: SE-Man ]</small>
- Kokiriwave
Re: problemos
no i bought the car off my parental units...
Should i just make my own homemade intake?
I want MAZDASPEED!
- SE-Man
Re: problemos
Yea, you can make it Cold Air, it works better then your stock air box.
- Kokiriwave
Re: problemos
I'd rather get the filter hose fixed? u've got message.
I want MAZDASPEED!
