KLZE manifold on K8???
Posted: November 28th, 2003, 2:09 pm
by MazdaManMike
I found out that my distributer is gone, and instead of fixing my 380000 KM engine i am going to buy a new one. I think i am going to try to be different and buy the K8(my original engine) and make it as good as possible. i just have a couple of questions i thought someone may be able to help me out with
1. Where is a good place to buy a GOOD QUALITY K8??
2.can a KLZE intake manifold fit on a K8 as a direct replacement. will i get more HP???
Re: KLZE manifold on K8???
Posted: November 28th, 2003, 3:11 pm
by Manach
Humm, about the intake,
No, don't use the KL-ZE intake, as there will be too much turbulence in the air, then creating less power..
If you need a new engine, buy a KF-ZE.. They are cheaper in price than a K8 or KL engine, and produce more HP..
The trouble, if you need any gaskets, you'll go custom afterward.
Posted: November 28th, 2003, 3:16 pm
by Custommx3
What hes referring to is mounting the KLZE w/ Square intake runner ports on a head with round ports. It will hit the edges of the head and cause air turbulance.
I got lucky and picked up my KFZE for 277.50 shipped on Ebay. I guess it was before the engine was known in the mx-3 community.
<img src="http://www.barrykclark.com/pix/GS/KFZE/ ... label1.jpg" alt=" - " />
as you can tell its very clean. Check on Ebay or a JDM engine distributor 1st and check on KFZEs. There are a few people on the list that can get ECUs as well if you cant get one.
<small>[ November 28, 2003, 02:23 PM: Message edited by: Custommx3 ]</small>
Posted: November 28th, 2003, 4:55 pm
by Gro Harlem
Dyno sheet? :roll:
