kl-ze won't turn over
Posted: October 12th, 2003, 10:04 pm
by mightym0use5
I am using th mx-3 vaf and manifold with the kl-ze ecu. my manifold is coming in soon. ok here is what happened my car was running fine with the upgraded ecu but then i recieved my actual kl-ze ecu i put it in but i pluged it in (just all the electrical plugs) and turn on the car and it was fine. Then I took out my old ecu and screwed it in kl-ze one using the mx-3 brackets from the old ecu, but now my car does not start. It cranks, but it does not turn over. - My idle was really low when i first got it tot turn on - do you think i might have to change the tps or reset the ecu? Any opinions of what it could be would help - thank you.
Re: kl-ze won't turn over
Posted: October 12th, 2003, 10:27 pm
by Nd4SpdSe
I had the same problem, it as my ZE's distrubutor, i used my old K8's and it worked fine
Posted: October 13th, 2003, 1:00 am
by mightym0use5
Thanks for your suggestion but I am using my k8 distributer. Any other thing it could be?
Posted: October 13th, 2003, 1:05 am
by Zoso124
Are you sure all three plugs are all the way in? You said it won't turn over, so you obviously don't have power to the starter or is it cranking and not firing? Switch ECU's again and see what it does.
Posted: October 13th, 2003, 1:06 pm
by mightym0use5
Ok - i pluged in my old ecu and nothing - same thing happens. I am so confused, It was working fine that morning and now it won't even start. I don't get it. It is cranking, but not firing (as in not turning on). - What is the diffirence in not firing to not turning over? Well if anyone has some input on my problem - i am open to all suggestions.
Posted: October 13th, 2003, 3:43 pm
by Zoso124
You might not have a good ground. From what I remember there were a few wires that were bolted down near they ECU. You didn't disconnect the Fuel Pump Relay thats bolted to the ECU?
Posted: October 15th, 2003, 12:25 am
by mightym0use5
The relay is still connected. I am not sure about the ground wires though. Where would they be. -thanks for all the help.
Posted: October 16th, 2003, 11:26 pm
by timpronk
If you pulled on the wires and not the actual plug, maybe one of the wires came out of the plug. I would look at all the wires and make sure none of them are partially out of the connector that plugs into the ecu.
