Radiator Fan Always on with ZE Ecu/Jspec ecu=no cel code
I just put the ZE ECU in my car and let me tell you it does make a huge difference. The only problem is that the radiator fan is always on. Its a 95 mx-3 with the ze. I know my old K8 only had 2 temp sensors and the older mx-3s have 3. Could that be the problem and if so will that put the ZE ECU in limp mode and can it be fixed. Do ZE ECU's have a check engine light?
Re: Radiator Fan Always on with ZE Ecu/Jspec ecu=no cel code
I have the same problem with my 95 PGT<p>Both fans come on at high speed and stay on<p>are you using the ZE TB/TPS?<p>I wondering cuase I'm using a KLD TPS and I'm trying to figure out why it's doing this<p>that temp sensor missing is interesting
I am using my stock tb abd tps bit I guess the fan coming on and staying on is a commom thing with the ze ecu
