Question on custom intakes
Iv decided to follow D coleman's advice and fit a custom intake to my 1.8 V6<p>1. If I want to rplace the rubber bellows between the Throttle body and the air flow meter, what do I do with the small pipe that goes i at 90 degrees to the bellows ? I was hoping to connect the throttle body straight to the airflow meter with a simple short length of pipe. My bellows is split and needs replacing anyway.<p>2. There is a small vac pipe going into the air box. Can it be blanked off?<p>3. With the air filter hanging down so low, does it take excessive regular cleaning? I live in UK so the car will be driven in the wet for 33 percent of the time!
MX-3 1.8 V6, 120000 miles. Aqua green metallic.My car domain page is here. http://www.cardomain.com/member_pages/view_page.pl?page_id=395842&page=2
- babyblueMX3
Re: Question on custom intakes
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by dancake:
2. There is a small vac pipe going into the air box. Can it be blanked off?<p><hr></blockquote><p>No don't do that.. I did and after that my idle was crap..leave it pluged like it is..Their's 2 vaccum plugged with a connector on a braket..don't touch this setup..just relocate it somewhere else..And the vaccum lines pluged on the OEM tube (the big and smal one)..Just replug them on your new piping
RIP 400whp ZE-T MX-3
Just get a foot long peice of tube and one 90 degree bend. You need 4 couplings 3 3in. to 3 in. ad one 2.5 to 3 to hook to your throttle body. You shouldnt have any problem with it being down to low i ha a hole cut in my bottom splash guard and my filter stuck in it. You can see it from undrneath the car. I did plug the Tube that comes off the ribs , well i put a filter on it. Mine works fne an i can tell a huge difference.
65 shot > V8
thats good news. In fact I looked earlier on and was considering a similar thing (putting filter through guard)<p>I guess I can clean filter regularly if needed.<p>Going to have a go this weekend. Do you use a generic 3" cone filter? Or do people find a particular make works best?<p>(what about the mushrooms on ebay? any good?)
[QB]Do you use a generic 3" cone filter? Or do people find a particular make works best?<p>QB]<hr></blockquote><p>I used a Ractive heat shield filter. It's about $40. The filter itself is kinda small (surface area) since its just an actual cone shape rather than a cylindrical shape. But the kewl part is that it already has a heat shield.
Iv heard others say this. Im bidding on a 3" ractive at the moment (the only one in UK on ebay) well see if i get it.
Yep I have a Ractive Heat Shield Filter on my MX-3 and my MX-5. They work great, sound great, and can be color coded to match your car! ![Smile :-)](./images/smilies/icon_smile.gif)
1995 Blaze Red RS 5sp. Manual, Pacesetter Exhaust, Custom CAI, 17" ADR Rims, Kumho Tires, Altezzas, GS Style Spoiler and Mud Guards, Neoprene Seat Covers, Aluminum Foot Pedals, Leather Shift Knob, Remote Starter, Blaupunkt Stereo and 5-disc changer, Pioneer Speakers, Amp, and Sub<p>http://www.cardomain.com/id/lendogg<p>http://www.msu.edu/~leonar40/Car.html<p>![Image](http://www.msu.edu/~leonar40/car/signature.jpg)
Where should the pipe/hose be plugged then? When removing the air box there's no place to plug it.Originally posted by babyblueMX3:
<small>[ April 26, 2004, 02:58 PM: Message edited by: Macen ]</small>
