Page 1 of 2
k8 turbo yes or no?
Posted: August 1st, 2003, 12:05 am
by BucktownMx3
would it be hard to do and would it be worth it to turbo the 1.8L v-6 in my 94 gs? im askin because my brother in law has a turbo that he would almost practically give me. so i wanna know if it owuld be worth whiel to turbo the 1.8<p>info is appreciated
Re: k8 turbo yes or no?
Posted: August 1st, 2003, 12:24 am
by Nd4SpdSe
its possible, there a guy i believe on here that has it done, he lives near TO, i've seen it in person...
Posted: August 1st, 2003, 11:49 am
by phr34k
nd4 go drive your kl and his k8 turbo and kinda give us an overview of which has more power
Posted: August 1st, 2003, 12:25 pm
by Guest
Its more then possible, the k8 engine is near turbo ready as far as internals go. If you have the means to do it yourself, and do it good you'd be surpassing any na/kl engine.
Posted: August 1st, 2003, 12:58 pm
by Spydie
i have N2O on my K8...surpasses (most)KL engines....but.....a KL with N2O, or turbo is the ****. I'd rather have a turbo too. I encourage this project. I'll be doing a turbo as well but not until I get another 2.5 to replace my last one
Posted: August 1st, 2003, 1:09 pm
by shocker
ya the guys name on here is mr spanky, his car is sick, if you want to look at his set up, go to torontomx3.com and look for the 2003 mississauga meet pictures, im sure there is one in there
Posted: August 1st, 2003, 5:53 pm
by BucktownMx3
how big of a turbo could i go on a k8? he owns his own garage and said if i baught it form him he would install everythign for me. he has been a mechanic all his life as well. so has my dad. and a k8 turbo would beat a naturally aspirated kl-zed mx-3?<p>and i wont need to strengthen my internals or ne thing right.? cause i will probably make my k8 a turbo if the price is right on the turbo. ne thing else u guys think i should do if i get a turbo for it? besides an intercooler. <p>ne one have a front body kit or ne thing they r willing to sell me? e-mail at
bucktownballer2@yahoo.com if u do.<p>thanks for the info. keep it comin if uguys want.<p>[ August 01, 2003: Message edited by: BucktownMx3 ]</p>
Posted: August 1st, 2003, 6:05 pm
by Spydie
T3/T4 hybrids seem pretty common....aren't they?
Posted: August 1st, 2003, 6:14 pm
by Zoso124
cheapest part is the turbo, fabrication and accessories cost all the money. Buy the book Maximum Boost by Corky Bell.
Posted: August 1st, 2003, 6:22 pm
by Guest
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by BucktownMx3:
and a k8 turbo would beat a naturally aspirated kl-zed mx-3? <hr></blockquote><p>Ya for sure, ze's are only putting down like 170whp in most cases, you could get there no problem with turbo, and exceed it with a nice set up.
Posted: August 1st, 2003, 6:49 pm
by lakersfan1
If you are going with a relatively light boost, you might be able to get a turbo from a scrapped motor pretty cheap in good condition. Last year, by brother-inlaw's neighbor was doing a turbo project. Came back from the junkyward one day with a T28 from a 2000 Audi A6 2.7T. Was pretty much mint since it was only a couple days old.....cost?? $50.00 He also got some kind of an obnoxious like T78 off a tractor turbo diesel for that much. But I think a T78 would be stupid on the K8. Get a nice T28 - T30/40 and you should be fine. But the bulk of the cost, as indicated above will be custom install and dyno tuning. Parts for a low-boost, simple turbo should be only a few hundred. More if you get on board with some kind of computer controller.
Posted: August 1st, 2003, 7:34 pm
by Bri94GS
You could prob find these turbos pretty easy: a 14b from a 1st gen DSM, a t-25 from a 2nd gen DSM, and I'm sure k-03's are out there as well, from VW/Audi 1.8T
Posted: August 1st, 2003, 10:27 pm
by TsiMiata
a 14B would work pertty well. They are good to ~300hp. The T25 is weezing at under 250hp.
Posted: August 2nd, 2003, 10:51 am
by mrspanky79
First off you need to do research! I research and picked up parts for a year then it took me 3 month to build the thing. And i have had it on the road since the spring and everytime i get behined the wheel or try to kill another bug in the system i learn somthing new. There is lots to learn, figure out and plan before you even start. The cheapest part is the turbo you will also need a bov, boost conroler, intercooler,upgrade fuel system, lots of gauges, oil and cooling lines, relocate the battery,and all the plumming just for starter. All that there is over $1,000 plus you always have to be tunning and be playing with the motor(become one with it
) its not like a 2.5l where you can just drop it in and be on your maryway with very little to look after.
Posted: August 2nd, 2003, 11:13 am
by mrspanky79
Im using a 99 T25 and well decribe the way it feels hmm the first thing that come to mined its like a little irish boxer
. Just like any other little guy on the block normal with a bit of an accent when he talks but if you step on his toes he explodes like no tomarrow.
I can play behined the wheel allday the only down fall that I have come across driving wise is i have to shift real fast now it climbs throw the rpm band like no tomarrow almost wish i had taller gears. Im hoping that a new clutch this winter will help that a bit the 10 year old stocker is not cutting it any more.
