Help!...Having engine problems.
Posted: July 13th, 2003, 11:11 pm
by Ebsouljah
I was driving on the highway. Suddenly, my car dies. I try to start it and it will only keep running if i keep giving it alittle gas. It runns reallly ruff and i hear "valve clack"...My step dad told me my timing belt might have jumped a couple teeth...And is there anywhere to hook up a timing light??? :shrug: <p>Thanx in advance,
Mykil²
Re: Help!...Having engine problems.
Posted: July 14th, 2003, 10:00 am
by pbr
it sounds like a bad timing belt tensioner let your belt slip. Need to replace with new
Posted: July 14th, 2003, 2:03 pm
by Zoso124
The chances of the belt jumping while driving on the highway are very slim. Most times when the belt jumps its when you it the gas really hard. "Valve Clack" isn't a good sound, my guess is you might of dropped a valve. My suggestion to you would be do a compression check before you try to keep the car running to see if its in time. Remove all the plugs, disconnect the wireharnasses going to the disty and the fuel rails. Also pull the big fuse for the fuel pump. Then test each cylinders compression. You'll know right away if there is a problem.
Posted: July 15th, 2003, 12:02 am
by Ebsouljah
Well,<p> I did a compression test and the #4 cylinder has no compression at all!! Im trying to get my mom to help me out and get he ze!!
