diff between aluminum and copper radiators...
ghandi1981
what is the difference between the two type of radiators and which one should i get to replace the one i have now? also, where to find a good place to get one...thanks<p>aj
resurected KL-ZE,ZE ECU, 9lb Fidanza Flywheel, CMIII, home depot CAI, Hiflow Cat, 2 1/2" piping, exhaust, 2 MASS 2012's, Cadence A7, Blaupunkt Casablanca, and a no damn CEL light!!!
Gro Harlem
Re: diff between aluminum and copper radiators...
alumnium = lighter, less efficient, easy to destroy. <p>Copper = heavier, more effecient, harder to destroy
DONATE TO MX-3.COM
DONATE TO MX-3.COM
ghandi1981
i thought Al was more efficient than Cu....<p>aj
lakersfan1
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by ghandi1981:
i thought Al was more efficient than Cu....<p>aj<hr></blockquote><p>If that was true, then high performance computer chip coolers would use aluminum instead of a copper mating surface.
- goldsberry1
would it be possible for us to get one? how much would it cost? and where to get one? i m not sure if it would be worth the weight though.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
killerpickle
umm, Im just going to guess that the copper rad would weigh 2-3 times more (if not more) than the aluminum.
Tom Alexander
