K8 ECU Pinouts
Posted: June 5th, 2003, 9:33 pm
by Anto
Does anyone have a diagram or know where I could find the pinout for the 92 v6 k8 ecu. I'm trying to install my S-AFC and I can't find the MAF pins off the ECU.<p>Any help is appreciated.<p>Anto
Re: K8 ECU Pinouts
Posted: June 5th, 2003, 11:38 pm
by Zoso124
Thank god for Jeff Abrams..<p>
http://www.mazdamaniac.com/shop_man/f2-083.gif<p>If you can't see the bottom of the page cause its so small let me know and I'll try to take a pic of the manual.<p>[ June 05, 2003: Message edited by: Zoso124 ]</p>
Re: K8 ECU Pinouts
Posted: June 6th, 2003, 2:55 am
by Anto
Ahh, thanks a bunch!
The images will suffice.<p>Too bad we can't have a pinout like these guys:
http://www.vfaq.com/mods/ecu-harness-1G.html<p>But oh well, I'll make it work. Thanks again.<p>Antonio
Re: K8 ECU Pinouts
Posted: June 6th, 2003, 8:49 am
by Zoso124
There is something similar but you have to look for it sorry.
Re: K8 ECU Pinouts
Posted: June 7th, 2003, 7:23 am
by BATTOSAI
Re: K8 ECU Pinouts
Posted: June 7th, 2003, 1:48 pm
by Anto
I've seen the super probe site already, it's irrelevant. They don't have the k8 ecu and their wiring harness is different.<p>All the other links on that post are useless, it seems to be discussing turbo pictures.<p>Have you installed the s-afc on your k8 mx3?<p>Anto
Re: K8 ECU Pinouts
Posted: June 9th, 2003, 7:39 am
by BATTOSAI
Yes, and it works correct!
Re: K8 ECU Pinouts
Posted: June 9th, 2003, 7:41 am
by BATTOSAI
Yes, and it works correct! Don´t you know that people that swap engines for the Kl doesn´t have to modify the harness? Maybe it´s because the ecu pins are mainly the same! check the workshop manual for the cable colour, it may be different, but the pin location should be the same
