Putting new drive axle in
93MX3SpecialEdition
Post by 93MX3SpecialEdition »
I need to put a new right side drive axle in my car. I am wondering how hard it is to do myself?<p>Please reply asap!!<p>Thanks!!!
dewthis
Re: Putting new drive axle in
Post by dewthis »
Its really not that hard ,i got real used to it doing my swap. Really allyou have to do is take the wheel off, brake caliper, rotor will slide offthen. My suggestion is to take the lower ball joint loose from the control arm it is just two bolts i think they are like 17 or 18mm. Then it will take a little prying depending on how long they have been in. Pop the old out and slide the new in if it is the passenger side you have three bolts that are attached to the back of the motor. Anyways its not that hard just a little patience.
65 shot > V8
