2.5 KL Engine SWAP
Posted: February 23rd, 2003, 12:20 am
by Machelski65
Few questions my 2.5 has the intake manifold that the tubing to the air intake go straight and on the mx-3 would hit the battery. So my question is, Is it ok performance wise to use my intake manifold off my 1.8? I would of course use the 2.5 injectors? Also should I get the MAF and ECU from the MX-6 I got the 2.5 out of and run it on them? Thanks in advance for the help... A.J.
Re: 2.5 KL Engine SWAP
Posted: February 23rd, 2003, 4:21 am
by curtklze
yes, use your stock intake, 2.5 ECU and 2.5 VAF
Posted: February 23rd, 2003, 4:48 am
by IanL
I'm contemplating the same job, so I've done the research, posted some questions and got answers (thanks all).<p>You can use an IM from a US 2.5L Millenia; the neck is curved.<p>I think you mean VAF (not MAF) and ECU from the MX-6. As long as the MX-6 is pre 96 (i.e. OBD1)that will work. If its 96-on (OBDII), get an OBD1 ECU.<p>Good advice on
http://www.geocities.com/motorcity/downs/8175/swap.htm , but use the MX-3 exhaust manifold, and you don't need to cut & weld the exhaust downpipe; see as it says on
http://www.geocities.com/MotorCity/Downs/8175/myswap.htm<p>Good luck!<p>[ February 24, 2003: Message edited by: IanL ]</p>
Posted: February 24th, 2003, 12:10 am
by Machelski65
Thanks Kurt and Ian now just gotta find time to work on it. I did mean VAF. Well, think you guys gave me all the answers I need so should be smooth sailin. Thanks again and have a good one. A.J.
Posted: February 24th, 2003, 2:43 am
by 93mxrgs
or.. save yourself some head aches.. and some power, and get a smaller battery, you must be running a tractor battery cause i never have any problems w/ the 03 manifold..
Posted: February 24th, 2003, 2:58 pm
by Machelski65
I don't know if its gonna hit or not. My batteries normal size. You just used the 2.5 intake and had no problems? I've just read that everyone does use the bent tubed intake.
Posted: February 24th, 2003, 5:56 pm
by IanL
Looking again at
http://www.geocities.com/MotorCity/Downs/8175/myswap.htm it seems the KLD manifold out of the 626 is OK; it must be shorter than the straight manifold on KLZEs which people replace with the Millenia IM.<p>[ February 24, 2003: Message edited by: IanL ]</p>
