Twin Turbo klze
Posted: January 1st, 2003, 12:28 am
by BLINDMAN INC.
Is there a way the intake could be split to have two seperate banks ? I'm asking this because I'm wanting to make a twin turbo klze.
Re: Twin Turbo klze
Posted: January 1st, 2003, 1:28 am
by Q187
There's always a way. The real question is do you have enough money to do it.
Re: Twin Turbo klze
Posted: January 1st, 2003, 10:10 pm
by Talon_66
Search for this topic also, u'll find more
Re: Twin Turbo klze
Posted: January 1st, 2003, 10:59 pm
by VizualXTC
Most likely you'd want seperate intakes for each turbo. I've seen some setups where the intake filter was connected directly to the compressor. I've also seen setups with 2 seperate cold air setups. If you break 1 into 2 it will only restrict airflow. I'd go with the 2 filter setup.
