hey look plz
MI-Archangel
hey look plz
Post by MI-Archangel »
<A HREF="http://www.cardomain.com/member_pages/v ... zda%20MX-3" TARGET=_blank>Mikes Site</A><P><BR>hey everyone those are pics of my car above and 4 all of those who looked their is a pic of under my hood and i kept the airbox tube to bring cold air to the engine does it actually work or should i take it out thanks
Shadow_Mx-3
Re: hey look plz
Post by Shadow_Mx-3 »
Are you talking about the plastic tubing in front of the engine near where the hood latch is ?
Jean-François
Now Mazda MP3 2001 Owner
The MX-3 is sold !
MI-Archangel
Re: hey look plz
yes i am
Shadow_Mx-3
Re: hey look plz
If you have and aftermarket filter (which you seem to have from your pictures) you can remove it.<P>It was used to send cold air to the OEM air intake filter box.
Jean-François
The MX-3 is sold !
MI-Archangel
Re: hey look plz
yes but will it be benficial to keep in the tube
Shadow_Mx-3
Re: hey look plz
I don't think it will help that much since the filter will mostly suck in air from the engine bay at idle and maybe a little bit of fresh air from that tubing part at high speeds.<P>But the gains will be minimal. I suggest you do another piece of tubing that would go around the filter for it to suck in fresh air directly.<P>This here are examples of what i am talking about:<BR> <A HREF="http://www.geocities.com/MotorCity/Down ... ramair.htm" TARGET=_blank>http://www.geocities.com/MotorCity/Down ... air.htm</A> <A HREF="http://www.geocities.com/MotorCity/Down ... amair2.htm" TARGET=_blank>http://www.geocities.com/MotorCity/Down ... ir2.htm</A>
Jean-François
The MX-3 is sold !
Rick Johnson
Re: hey look plz
Post by Rick Johnson »
If you take that out then where do you put the hood prop rod?
lazzyie
Re: hey look plz
Post by lazzyie »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Mazstyle:<BR><STRONG>If you take that out then where do you put the hood prop rod?</STRONG><HR></BLOCKQUOTE><BR>drill the rivits out of that stupid air box and then use one of the screws/holes to mount it on the radiator garnish<p>[ October 31, 2002: Message edited by: lazzyie ]
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
chance
Re: hey look plz
Post by chance »
just set it top of you fan shroud or make your own bracket
