Motor mounts and poly inserts...?'s
Hulloooo.....<BR> I've busted the front (next to the rad.)motor mount on my GS V6. I've seen the poly inserts you can put on your motor mounts. My questino is this... if your motor mount is missing a lot of the rubber around the metal sleeve through the middle of the mount, will the poly inserts do the job of the mount? Has anyone used these? Thx!<P>Whitefish... WASSUP?!? ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Jason B
1993 MX-3 GS
1.8 V6 5 speed
1993 MX-3 GS
1.8 V6 5 speed
Re: Motor mounts and poly inserts...?'s
i've never heard of anyone using poly inserts to "rebuild" the mount. I would think that you would have to keep applying inserts every 5000 miles in order for that to help any. The mount itself is only like 120 from mazda though.
Shaun Newman
or $260 for all 4 mazdaspeed ones from corksport.com
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Sonicxtacy02:<BR><STRONG>i've never heard of anyone using poly inserts to "rebuild" the mount. I would think that you would have to keep applying inserts every 5000 miles in order for that to help any. The mount itself is only like 120 from mazda though.</STRONG><HR></BLOCKQUOTE><P>you can get each engine mount for ~60 bucks at any local parts store. If the originals are dead, you may want to buy the new oem pieces and then do a poly-fill.
-93 MR2
#129 E-stock
#129 E-stock
i stand corrected i got 2 for $120. Thanks Jesse
Shaun Newman
