WHITEFISH!!!
WHITEFISH!!!
Bro, <BR> didn't you make your cold air intake? Do you have some sort of diagram you could send me, or could you at least tell me the parts you used from Home Depot? I have a tear in my intake hose and can't afford either the replacement from Mazda or a cold air intake. Thx!<P>Jason ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Jason B
1993 MX-3 GS
1.8 V6 5 speed
1993 MX-3 GS
1.8 V6 5 speed
Re: WHITEFISH!!!
I used Sean's page to help me but it seems to be a porn site now<P>So I will try to explain <BR>parts list<BR>3" silicone/rubber adapter (its black and has a hose clamp on both ends)<BR>3" silicone adapter (its black on the inside but has like a steel wrap over that with a hose clamp on both side)<BR>but you may not need that depending on witch cone filter you buy<BR>About 1 foot and a half of 3" pvc drain pipe <BR>and a 3" 90 degree elbow <BR>and some glue<BR>A Cone filter<P>first 3" adapter goes on the VAF ~2-3 inch piece of drain pipe from the other end to the elbow dowm ~one foot to the filter as I said befor you may or may not need a adapter to atach the cone on the end<P>if you need any more help let me know
