Underdrive pulley
Underdrive pulley
Hey does anyone out there have one on there 1.8 or 2.5? Is it worth buying? How much hp do you think you gained?
white fish
Re: Underdrive pulley
4-6 whp
I'd say it's worth it. Worth it if you can do the work yourself and the belts need to be changed anyway.
Water pump and timing belt might also be a good idea to all do at the same time if your paying some one.<P>I actully did my timing belt, serpentine(sp?)belts, and water pump all at different times. hehe
But I can change belts like no ones business now though!
~SonicRacing~
i have onr form UR. I like it it was kinda hard to put on bein that u had to grind my engine down with dremil rotary tool. the only thing i hat is that, my belts are tightened fully and it makes that squeal noise, only when its cold though. but i do like it
white fish
the squeal is the belt slipping you need to tightin it or get a smaller belt
