I could use some help (identification and installation)
Car Stereo/Alarm Discussions
Absath
Post by Absath »
Hey guys. Recently I inherited a box full of car audio equipment. Now, I've installed CD decks and speakers with no trouble, but that's as far as my experience with audio equipment extends. I have never worked with amplifiers, subwoofers, any of that. So I need a bit of help here.
First of all, I'm going to need to identify what all of this stuff is, because most of it is "out of box" with no manuals or such. All of the equipment is from a company called ADS, which I have never heard of.
I'm hoping you guys can help me out with what each of these components are, and what it does:
I know that this is the amplifier (right?). It is an ADS PH12. According to the brochure I found in the box, it is a 6-channel system.
<img src="http://www.ctrlaltdel-online.com/temp/ads1.jpg" alt=" - " />
<img src="http://www.ctrlaltdel-online.com/temp/ads2.jpg" alt=" - " />
Next is something called an AX2 electronic crossover. I don't know what this is.
<img src="http://www.ctrlaltdel-online.com/temp/ads3.jpg" alt=" - " />
This one was in a box, which was labeled "AX3 programmable active filter module, 2-way/3-way electronic crossover"
<img src="http://www.ctrlaltdel-online.com/temp/ads4.jpg" alt=" - " />
And then there was this sound level meter in there too.
<img src="http://www.ctrlaltdel-online.com/temp/ads5.jpg" alt=" - " />
So what do I have here? The beginnings of a car audio system? If so, would anyone be willing to walk me through an installation, if I decided to go that route? Would it be better to just bring it all to a specialist and have them do it?
Any help here would be appreciated.
-Tim
<small>[ September 26, 2004, 11:40 PM: Message edited by: Absath ]</small>
Don't park drunk, accidents cause people.
92 Blaze Red MX-3 GS, KL-ZE, ACT Clutch, KL 36 ECU, SS Clutch Line
DJsMX-3
Re: I could use some help (identification and installation)
Post by DJsMX-3 »
I DONT know the brandname at all But electronic crossovers is normally used in good systems..
The way the electronic crossover works is it takes the full audio signal from your Headunit 15-22k(20-20khz)and parts it out into highs mids and lows @3way Like for excample Low 15-500Hz Mid 500-7000Hz High 7000-22000Hz or something like that,maybe you can even decide the crossoverfrequencies yourself :)
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
BumpNGlow
Post by BumpNGlow »
yep, DJ about summed it up.
The Sound Meter is a decibel microphone or SPL meter. It tops off at 130dB, but is GREAT for tuning boxes. They can be purchased at Radio Shack.
The equipment you have, A/D/S, is good schtuff, but is fairly dated. check out www.adst.com
FOR SALE, AS A PARTS CAR
Return to “Car Stereo/Alarm”
