Hi, I'll make this short. I unhooked my box and amp to clean my car. When I hooked it back up, the left speaker in the box won't work. I checked all connections, on the box, on the sub, on the amp, the fuses on the amp, even the rca's going to the radio. Is there any other reason that sub wouldn't work? The other (right) one works fine. Would the sub just stop working if it was blown? Thank you in advance.
<img src="http://images.cardomain.com/member_imag ... 9_full.jpg" alt=" - " />
Here's a pic, so you can see the type of enclosure it is.
Quick question about subs, please help ASAP!
xXx_OTEP_xXx
Re: Quick question about subs, please help ASAP!
Did you cross the wires that you know of?
Did the copper parts of the positive and negative touch each other while they were hooked to the amp (after the subs were out obviously)?
That could screw up your amp a little bit, that's the only input I have to offer.. better than nothing i guess.. Good luck
Sold my 95 RS "Little Peanut" but she will never be forgotten.
- 2fazed
I'd take that sub out and test it on your home system. If you get any noise, then it's your amp or connection. If you only get distortion or a muffled noise, that sub is blown.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
