Replace OEM Deck with Aftermarket will it fit?
Posted: November 29th, 2002, 11:28 pm
by MX3Gurl
Hey gang, i'm going to be replacing my OEM deck from my 95 MX-3 GS and was wondering if i need a kit (faceplate) to make it fit snug? <BR>i'll be replacing it with an Alpine head unit CDM-7874.<P>oh, and yes i already bought the harness (makes it so much easier...)
<P>Thanks again.
Re: Replace OEM Deck with Aftermarket will it fit?
Posted: December 1st, 2002, 4:04 am
by quinn_seipp
should fit just nicely
Posted: December 1st, 2002, 10:49 am
by mzdspd
if it is single din size it will fit with no problem at all
Posted: December 1st, 2002, 12:00 pm
by Psyrg
As the OEM headuint in my MX-3 is double DIN, if you install a single DIN sized headunit you may require a spaer of sorts to fill the gap. Theres are quite easy to get, if one is needed dont hesitate to get your headunit salseman to throw one in with the deal.
Posted: December 1st, 2002, 10:34 pm
by airjordon_09
the alpine's fit the mx-3 with no probs at all, they dont fit many cars perfectly, but ours is one it does fit perfect , the love for alpine
Posted: December 2nd, 2002, 1:11 am
by BumpNGlow
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Psyrg:<BR><STRONG>As the OEM headuint in my MX-3 is double DIN, if you install a single DIN sized headunit you may require a spaer of sorts to fill the gap. Theres are quite easy to get, if one is needed dont hesitate to get your headunit salseman to throw one in with the deal.</STRONG><HR></BLOCKQUOTE><P>yah -- I don't see how everyone is saying its a perfect fit -- don't you guys remember adding a lil pocket?
Posted: December 2nd, 2002, 10:20 am
by Sonicxtacy02
a single din sized unit will fit the single din sized opening provided you have the pocket that occupies the second din. Some radios in the mx (92-93's i suppose) came with a double din unit in which case you would need some sort of spacer/filler for the second (lower) din slot.
Posted: December 3rd, 2002, 12:45 am
by MX3Gurl
Thanks guys, the deck fit perfectly.
