cluster
Posted: June 28th, 2002, 7:44 pm
by mitmaks
anyone can help me out please i cant find anywhere how to remove trim around cluster i need to get to it to put in indiglo gauges and i took thee screws from top of it and i dont know whats holding it on bottom <BR>thank you .
Re: cluster
Posted: July 1st, 2002, 11:12 am
by Golliwog
Believe you have to remove the entire panel underneath.
There's two screws to the left of the steering colum (sp) that are under it I think. <P>Check out <A HREF="
http://www.mazdamaniac.com/" TARGET=_blank>
http://www.mazdamaniac.com/</A> <P>I think he has a pretty good guide on how to install the gauges (including removing the cluster), as well as some other cool things!
Re: cluster
Posted: July 1st, 2002, 11:32 am
by Swego
There are 2 other screws at the bottom of the part. You have to remove the stearing shaft top cover to access them. The screws are behind a rubber flap.
