oil troubles
dr. gonzo
oil troubles
i just replaced a head gasket. now the oil is a light cream color......what did i do?!? it sealded nicely, and i know its not coolant cause i havent put any in yet, i just started it to make sure it worked. please help.
some peoples kids.
dr. gonzo
Re: oil troubles
im assuming some of the coolant got into the block when i had the head off. thats my only logical explanation. what do i need to do to clear this up.
some peoples kids.
Re: oil troubles
If thats the case, change the oil and check for coolant again?
Black 94 RS, Erebuni MS style front, OEM sideskirts, Clear signals, altezza tails, 93 seats, Civic projectors
Re: oil troubles
you may have to change the oil more than once if a lot of coolant got in there. Change it, drive it for a while, change it again. Blow head gaskets are a b-otch!
