You know those "test pipes" you see on ebay? Here, this is one:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33633&item=7934658431&rd=1
It SAYS it will bolt to the 1.8 liter exhaust system, but would it fit on the sohc 1.6?
Is the piping and cat the same for both engines, after the downpipe?
Thanks a lot
Test Pipes?
Re: Test Pipes?
It will not fit the 1.6 SOHC.
Re: Test Pipes?
Thankyou!
Re: Test Pipes?
What is it anyway??? ![Shrug :shrug:](./images/smilies/shrug.gif)
Re: Test Pipes?
Just a straight-through pipe with flanges welded to the ends. For off road use only, it bolts in as a replacement for the more restrictive catalytic converter.
