wont start
Posted: October 28th, 2004, 9:09 pm
by Pearl-JapSpec
well i put my rad back in finally and i tried to start up my car and it would turn over once and then just make a clicking noise...
my stepfather says the battery is dead but it still wouldnt start when getting a boost...
im baffled what could it b.
Re: wont start
Posted: October 29th, 2004, 2:09 am
by Typhoonk
things to check
1. Remove starter from engine. apply 12volts to it for a sec and see if it cranks(have to hold it down or bolt it to something so it doesn't move). Check the little gear in it that turns the engine.
2. Flywheel might be missing some teeth. Try roll starting the engine
3. Check all fuses in car.
Posted: October 14th, 2007, 11:51 pm
by don93pgt
starter connection check ground usually clicking means low batterymake sure everything is clean and connected properly
