B6 question
Ruben MX-3
B6 question
Post by Ruben MX-3 »
hey ppl, anyone know of any different ecu's that would fit our cars stock B6 wiring harness for more power?
Joe Carlson
Re: B6 question
Post by Joe Carlson »
I'm not sure, but i think you can use the bp ecu and get quite a bit more power. you can use alot of peices off of the bp to get more power, but you know i'm not totally sure.
Thanks-Joe
92 MX-3 1.8L DOHC BP, 17" Konig wheels, 2.5 exuast, custom CAI, inverted style carbon fiber hood, GT-Combat body kit.
Re: B6 question
Post by Josh »
if you have the 92-93 sohc then you can swap between the BP. if you have the 94-95, your pretty much screwed. the 94-95 is only swapable to itself. other than a few misc parts like the distributor, injectors and such. but no ECU swap.
Ruben MX-3
Re: B6 question
:crying: SIGH!!!! THANKS ANYWAYS GUYS!
ciao
m92_MX3
Re: B6 question
Post by m92_MX3 »
so i can take any ECU out of a BP and put it in my 92 SOHC and get more power ?
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
Marlon
Re: B6 question
Post by Marlon »
NO!!!!!!!!!
don't do it
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
manowar821
Re: B6 question
Post by manowar821 »
LOL, YES OR NO!
Because I hate my sohc 92 ECU.
Thankyou ^_^
m92_MX3
Re: B6 question
Post by m92_MX3 »
why ? what happends if i do it ? whats bad ?
CTC Racing
92 1.6L
OsoSlo z28
Re: B6 question
Post by OsoSlo z28 »
it's a difference of 200cc. you have a completely different engine that has different needs than a bp motor. the bp has a different pulse width along with a different size injector and is not a good thing on a stock b6 motor. (intake/exhaust is still stock)
the only time you see a benefit from using the bp ecu is when you have internal engine work done or a bp/b6t motor swap. this helps with a better fuel curve to work with.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
m92_MX3
Re: B6 question
Post by m92_MX3 »
so i would mess my motor up what if i have bigger injectors ?
CTC Racing
92 1.6L
OsoSlo z28
Re: B6 question
if you don't have a substantial increase of air coming into the motor, it would run like crap.
"MR." Ashley Fowler
cardomain pics
m92_MX3
Re: B6 question
Post by m92_MX3 »
so something more then cold air intake, like a turbo or some other type of forced induction ?
CTC Racing
92 1.6L
projectmx
Re: B6 question
Post by projectmx »
what about swaping the dohc ecu out for the miata ecu?
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Ruben MX-3
Re: B6 question
tru... wud the miata ecu work?
torpedan
Re: B6 question
Post by torpedan »
For the majority of intents and purposes you can not just swap the ECU. VArious sensors and at times full wiring harnesses must be adapted as well.
A miata uses DIS, you would have to swap that over as well to use a Miata ECU. This very likly modifying the wiring harness as of the engine in the mx3 sits transverse.
-torp.
I don't own a Mazda.
