valve problem?
valve problem?
what does alot of white smoke mean out the exhaust...? if you can please tell me all the posibilities.thanx
- Limegreen mx-3
Re: valve problem?
i remember reading something about ur head gasket could be leaking antifreeze getting into pistons causeing white somke to flow out. then again i could be wrong. then again mines does the same thing when its in the shop due to engine or tanny repairs during that time its out for like 2-3 months. white smoke comes out and after a 3-4 days of driving it it goes away. its better white than blue smoke.
Jteezy
Re: valve problem?
Well it can be alot of different things. Whens the last time you changed your oil?? Start small then go from there or else you'll burn a hole in your pocket.Peace
Re: valve problem?
Check the water level in your radiator. If you are losing water you almost certainly have a blown head gasket. Driving it this way can be bad.
