will not start?
zipad
will not start?
Post by zipad »
92 mx3 will turn over and want to start but doesn't. If I let it sit for about 40min it will. Only happens when it is cold or damp outside. I replaced distributor cap plus wires. I'm thinking fuel problum. What do you guy's think.`
maniac
Re: will not start?
Post by maniac »
mine was having similar symptoms and turned out ot be a bad sensor in the distributor. had to get a whole new one. Might wanna get it put on a computer to see what codes are coming up to get a better idea.
mitmaks
Re: will not start?
Post by mitmaks »
probably old battery, my lexus wouldnt start today, had to jump start it from mx3, would crank but wouldnt start, battery gets affected by cold temperatures especially old ones.
