ECU for my BPT...Help
Posted: December 23rd, 2003, 12:08 am
by mx3_pr
I installed my BPT engine but I dont know which is the better ECU that I can use...any idea?
Re: ECU for my BPT...Help
Posted: December 23rd, 2003, 2:47 am
by philcosta
you can reprogram you stock ECU(not recommanded)
i had the stock ECU from my 1.6 93 RS SOCH. Car running great but i had very bad fuel economie changed to a bp26 cost me 230$US
#1 bp26 (japan) Stock ECU GTX ( more aggressive then bp55
#2 bp55 (australia) Stock ECU GTX
#3 use stock Mx-3 ECU
<small>[ December 23, 2003, 05:15 PM: Message edited by: philcosta ]</small>
Posted: December 23rd, 2003, 5:06 am
by Damien
#4 Standalone (more aggressive then any listed in the previous post & definately the best way to go).
Posted: December 23rd, 2003, 7:01 am
by mx3_pr
And, where I can buy one bp26 (japan) Stock ECU GTX or a bp55 (australia)GTX??? and how much will cost a stand alone system??....
Posted: December 23rd, 2003, 9:50 am
by OsoSlo z28
you CANNOT reprogram the stock ecu successfully. Trust me, i was a guinea pig for 3 trial ecu's, NONE of them worked.
options are this:
1- if you have a sohc, use the pro lx ecu along with a piggy back(easiest setup, not the best)
2- if you have the dohc, swap all the wiring over from the gtx.(horrible choice)
3- buy a stand-alone system.(same difficulty as #2, but a lot better.
it's funny how people spend all this money to get a turbo/swap going, but neglect or cheap-out on the MOST IMPORTANT part of the swap.
Posted: December 23rd, 2003, 2:28 pm
by Sonicxtacy02
that would be cause most people feel the "pssssst" is the most important part
