low gas mileage
Posted: November 28th, 2003, 4:06 pm
by illicitQ
before, my gas mileage was gettin low like around 26-30. then i change my spark plugs and wires, bosch +4 plat. and autolite wires from kreagan. i notice my gas mileage gettin lower still. last tank i got 22 and this time 26. what could be the problem? clutch? alternator?
Re: low gas mileage
Posted: December 4th, 2003, 1:35 am
by Darcy
I'm actually just curious what car you've got. That's about what I'm getting as well ( i set up a little logger at http://dukes.internetmaximum.com/gas.php to track my usage)
I'm driving a '93 1.597L and just recently put in new NGK Iridium IX plugs too (didn't seem to make a difference) I'm also getting the idle problem, but not as bad since the new plugs.
I went to the Mazda dealership, and they said I need an Oil Pressure switch, a distributor O-ring and new cam and crank seals. I'm not much of a mechanic, but common sense tells me that can't help the engine's efficiency.
I paid $40CAD for a multipoint inspection, and I think it's a good deal to see what's wrong.
Re: low gas mileage
Posted: December 4th, 2003, 9:30 am
by torpedan
Do you just get any gas anywhere or always use the same company/station.
My 1.6 DOHC would get 16mpg off of race track gas yet it would do 29 in the city off of texaco. Always somthin to look at.
Re: low gas mileage
Posted: December 4th, 2003, 6:38 pm
by Casino
esso gas is pee fuel never get it
Re: low gas mileage
Posted: December 6th, 2003, 1:40 am
by Freq2002
Did you change the cap & rotor when you did the wires & plugs? Those are the fastest wearing parts of the ignition system.
Get rid of the Platinums. They are made for people who dont like to get tuneups on a regular basis. They tend to decrease your milage as well. Get the NGK plugs, if you're worried about a solid spark go a step hotter.
May wanna look into an injection system cleaning, not the stuff you pour in the tank either. A real cleaning can make a load of difference.
Where you get the gas may or may not make a difference. Just a note, I tracked my milage for a couple years, & there is no noticable difference in milage between 87 octane & 92. Save your $$, just buy from a quality brand sation.
