I was wondering if anyone has done the PRC solenoid modification http://www.mx3gsr.freeservers.com/prc.htm
I was wondering if someone could explain to me how to do it so i can see if its really worth the loss in gas milage.
also...
dont know if this is true or not but if we disconnect our ecu for 2 hours will it relearn the new fuel curve because of my mods. i know it sounds honda ish but hey if it works ill try it, so does it?!? :p<p>[ March 16, 2003: Message edited by: The_Great_Tonge ]</p>
need some info please
- The_Great_Tonge
- ryanlindenberg
Re: need some info please
yes if you unplug the negative battery cable then your computer will relearn the fuel map. it doesn't have to be for 2 hours though. unplug it for 5 mins and hit the brake, then hook it up again. let your car idle for 5 mins without touching the gas.
CARDOMAIN WITH UPDATED PICS
- The_Great_Tonge
how about the PRC mod? any idea if it works?
