It could be many things!
-Check your oil, ticking is usely your valve lifters.
-oil should be changed every 3,000 miles
-your oil filter I'd recommend every other oil change.
-make sure your oil isn't low!!!!
-If your hearing a metallic ping or something that sounds like loose change than it is detonation.
-in this case check your timing
-it could also be slightly cloged injectors, fuel filter or even a failing fuel pump or regulator.
-Spark Plugs
-I run NGK V-power copper core plugs. Mine are changed every 5-10K miles depending on plug condition.
-One thing you can do to smooth out the top end w/ the stock ignition is to close the plug gap up to about .030, was recommended to me by Corksport. It also helps them keep from fouling so easily.
-If the insulator on your plugs are slightly brown your fine. It means normal wear. However it also is a sign they probably need to be replaced. Check out the back pages in any Haynes repair manual for examples and explenations of plug conditions and wear or damage.<p>All in all doing the following may help your car out any way.<p>-NGK V-Power plugs gaped to 0.030
-Magnecore KV85 8.5mm Competition Plug Wires
-Accel Super Stock universal ignition coil
-Borg Worner brass terminal distributor cap & rotor
-BOSH replacement oxygen sensor
-Red Line 10w-30 Full Synthetic Motor Oil
-Red Line water wetter
-K&N Performance Oil Filter, I used a larger than stock filter.
-Pro Blend Engine oil addative<p>These will help your motor run MUCH cooler & smoother than stock. Not to mention beter emissions, fuel mileage & longer life for your motor!!! Summitracing shaved .2 off thier Mustang Cobras 1/4 mile times just by changing the oil to Red Line Synthetic oil!
![Surprised :eek:](./images/smilies/icon_surprised.gif)
