won't stop sqeeking when started
westwingsi
Post by westwingsi »
hey guys i need a little help :(<BR>i got new belts put on my car, because one broke off, all done and went to start my car and it won't stop SQEEKING, i try belt dressing, but it's working. please if one know anything help me, this is my only car!
tinkertank
Re: won't stop sqeeking when started
Post by tinkertank »
sounds like one of your belts aren't tight enough. check the deflection of the belts. the proper tension should be in the online manual here.
MX-3 - 4 cyl. ('92)
DVH
Post by DVH »
I had the same problem, DON'T use belt dressing, that stuff just fu*ks ur belts up more, giv eit a few weeks, ur belt will break agian!!<BR>Go to Mazda and get them done, when they start squeeking again, which they will, go back and get them adjusted for free, i had mine adjusted 3 times after getting fixed, now they have been perfect for 3 months now!<BR>It was very embarrassing at car shows and meets...... :(.....get it done at mazda or if ur goin do it ur self , USE mazda belts!<BR>later :D
Derek Van Horne MX-3.com Member # 33
94 MX-3 Silver Stone Metallic CAR is SOLD
Car Domain Web page MX-3
Car Domain Web page SRT-4
Andrew_Pakula
Post by Andrew_Pakula »
If they have just been changed they should not be making horrible sqeeking noises. Take it back and make them fix it. Don't let them try to pawn off half-assed work on you.
fredsanford
Post by fredsanford »
When they squeek, It means they are slipping, Which creates heat, Which fucks the belt up and weakens it.<P> Make them put new belts on<P><BR>The bad one is the alternator belt, It has to be *surprisingly* tight, Believe me.
