Back-up lights
Back-up lights
My back up lights don't work. I checked the bulbs ant the wires at the back but don't know where to look after that....
Re: Back-up lights
maybe fuses?
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
- mmonid
Re: Back-up lights
Mine had a dead switch. Check that.
Matthew Monid
![Image](http://www3.sympatico.ca/monid/mx3/fade-mx3.jpg)
1993 MX-3 RS 5-Speed (Sold)/1997 Volvo 850 AWD Turbo 5-Speed
Re: Back-up lights
there is no fuses but where is the switch?
Re: Back-up lights
The backup lights get their power through the "backup" switch located on the tranny. Check the electrical system diagram posted in the shop manual available on this web site for details. I had the same problem. It was a little corrosion on the wire connector that attached to the switch. Perhaps the same problem affects your MX-3. Hope this helps.
Stan W.
Re: Back-up lights
sorry but can't find that with the diagram can you remember where it is on the tranny?
Re: Back-up lights
Hey I forgot to change my e-mail adress... can u send to the new one please<P><BR>Thanks
Re: Back-up lights
hey... is there anybody out there
![Wink ;-)](./images/smilies/icon_wink.gif)
Re: Back-up lights
When you are standing in front of the car, look down past the radiator in the direction of the engine/tranny. About 12 inches (guessing)right of center of the car on the front side of the tranny is the backup switch.<P>Hope this gets you in the general area and perhaps it's only a loose wire or such.<P>Stan
Stan W.
Re: Back-up lights
Thanks I found a ground wire that was disconnected...
