My car is leaking
My car is leaking
Today I noticed that my car was leaking. Its on the passengers side front wheel in the back of the wheel. Its this black stuff, it kinda looks like greese. Does anyone know what it is and what to do?
Guest
Re: My car is leaking
You could've blown a coolant hose. Mine had that same problem, didnt notice it though till a had a crack in the radiator and 3 blown hoses, now its in the shop getting fixed. You should get it checked out before it gets worse.
Guest
Also look for it else where in side the engine compartment. When I first noticed my engine overheating, there was coolant all over the front drive wheel well and the front grill.
- Shades
Whatever it is get it checked out soon...<P>Leaks can be a bigger pain the arse if you leave it...
"Do it ONCE, do it RIGHT!"
mazda20
If it is a tore boot than you need to definitely fix it now before you are replacing the cv joint like I had to last weekend.
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II
My MX-3 Website
My MX-3 Website
F***! How does this happen? Someone help me!!
And how much does this cost to be fixed?
Guest
It just happens over time, wear and tear. Or rough and bad driving, either one.
wu_tang6931
im leaking oil but cant find the leak. also after driving my car for like 30min i smell burning oil. but i cant find the prob
wu, what are you talking about? is it coming from under the hood? or is it the same problem I had?
