intakes?
redhot94mx
intakes?
i've got a 94 1.6 4 cyl. Im lookin to buy and intake! I need to know a good brand before i spend the money. Cold Air? or Regular? Also i have and automatic if that will answer any ?'s
Stevech_2001
Re: intakes?
ok here's the deal man...no company acually makes one specifically for the mx-3...except prm...but they are expensive as s---.....just get a "ractive" heat shield filter and put it on the end of the MAF...then later on you can stick some piping on the end of the filter<--cause it has a heat shield....and route a cold air setup....cheap and easy...
Steve
