Oil infiltrate in spark...
Can you help me ?<BR>Oil infiltrates in the tube where are the spark and their wire... <BR>Have You already heard about this kind of disorders and what can be the solution... <BR>It seems that its the gaskets (O ring) of the valve cover<BR>is it necessary to remove the intake to change those of the rear rolls?<BR>Can i roll without repairing them? <BR>If you have a solution contact me [img]shrug.gif"%20border="0[/img]
Re: Oil infiltrate in spark...
it's the valve cover gasket or spark plug gramet's......easy fix you could do it yourself no problem
Steve
Im not a expert in mechanic<P>what is the spark plug gramet's?<BR>Do i need to remove all the intake manifold to replace those gasket?<BR>and can i roll without fix it like for a couple of day ?<P>thanks<BR>icq 11946408
no man just remove the valve cover and they look like plastic cylinders that surround the plugs and separate it from the valve's and oil......I'd get it done by someone else if you don't feel confident
Steve
