will 18"x7.5" wheels fit an mx-3?
Posted: July 1st, 2001, 1:30 am
by JFERRELL20
will 18"x7.5" wheels fit a 92 gs? the wheels are 4x100/4x114.3 with a +45mm offset also, how much could i drop my car with 18"s? someone please lemme know<P><BR>justin<BR>
jferrell20@aol.com
Re: will 18"x7.5" wheels fit an mx-3?
Posted: July 1st, 2001, 2:33 am
by DiGiTaL
The wheels would fit fine.<BR>The wheel well gap would be almost exactly <BR>the same as your stock setup so you should<BR>be able to drop it the same amount.
Posted: July 1st, 2001, 10:35 am
by JFERRELL20
so if i threw some 18's on it, could i slam it or just drop it back to stock ride height?
Posted: July 4th, 2001, 2:09 pm
by JFERRELL20
ttt
Posted: July 5th, 2001, 4:04 pm
by DiGiTaL
How do you plan on dropping your ride.<BR>Springs, coil-overs, air shocks ??????<BR>If you are just going to use springs I dont see any problem with lowering your ride with those 18's.
Posted: July 5th, 2001, 4:59 pm
by JFERRELL20
i plan on using coi-overs
