DOT-3 or DOT-4 brake fluid
Who has upgraded their brake fluid to DOT-4 specs ?<BR>I need to buy brake fluid and am wondering if it is ok to do the upgrade when I work on the brake system this weekend.<P>Thanx
Re: DOT-3 or DOT-4 brake fluid
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Maddbuck:<BR><STRONG>Who has upgraded their brake fluid to DOT-4 specs ?<BR>I need to buy brake fluid and am wondering if it is ok to do the upgrade when I work on the brake system this weekend.<P>Thanx</STRONG><HR></BLOCKQUOTE><BR>i don't think u can use dot 4 cause it's syntick or something but u can use dot 5
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
I believe it's the other way around, dot-5 is synthetic and can't be used.
- Zoso124
You can use dot 4 but you will never ever see any difference unless your going to be running some kind of road course racing. If you not going to be doing that then I wouldn't worry about it. Only difference between dot 3 and 4 is a slightly higher boiling point.<P>Good luck
Mike Evans
Gone:
Gone:
