Bubble ing sounds from my Intake!!
Posted: July 12th, 2001, 10:03 pm
by Guest
Hi I have a 94 rs . when the car is running I can hear a bubbleing sound coming for the intake area, its more by the throttle body. All the hoses are intact and the main intake hose has no tears or holes in it, any suggestions as to what it could be? Chris
Re: Bubble ing sounds from my Intake!!
Posted: July 13th, 2001, 12:36 am
by jojo2k23
sounds like your car is back firin from the the intake or your gas is boilin.(forgot what causes that)ck your timing
Posted: July 17th, 2001, 4:30 pm
by Guest
Thankds for the reply, I havent checked the timing yet, timing lites are around $50-60 at Auto Zone, so , Ill need to wait a moment, I have another problem too, Its under, Intercoolers... in the performance category. any suggestions? Chris
Posted: July 24th, 2001, 7:55 pm
by jojo2k23
hey also ck if yur car is running lean.
Posted: July 27th, 2001, 2:16 pm
by Guest
Okay I finally got a Timing Gun, Ill check it out later tonite, On the engine running "Lean" How do I check that? The plugs are still "clean " looking, they are not white powdered or black. <P> Thanks SO Much for your Time, Chris <P> Ill see ya at the Drag wars , Right?? <BR> Hope so, Thanks again<BR>
