Check out my complete write-up.albarsv wrote:Yesterday I receive the headlights
They were packed very well and nothing is missing. Headlights seem better than on pictures![]()
Just some questions:
- the low beam position lights are the outer one? So I have to install the HID kit there, correct?
- the black led's wires is the ground or the +12V wire?
Any hint for mounting and/or connection?
Thanks
Offical Spyder MX3 Halo Projector headlight (Black / Chrome)
- fowljesse
Re: Offical Spyder MX3 Halo Projector headlight (Black / Chrome)
Thanks Jesse but....
where can I find your write-up?
I don't know very well this forum..
Thanks
Thanks
- Evo_Spec
you can find it here:
http://www.mx-3.com/phpBB3/viewtopic.php?f=38&t=68513" onclick="window.open(this.href);return false;
Thought you said you got the best ones?? Looks like quality control is lacking..... Mine don't wiggle!SuperK wrote:My projectors are kinda wobbly and not secure.... when the hood is up, I can take the light and wobble it back and forth... Anyone else's lights like this?
colinf004
Just received my lights in the mail yesterday!! LOOKS SWEET!!! after my engine is rebuilt I will put them in...
I know, it SUCKS, because I dunno what I have to do to fix it... it's the drivers side headlight that's wiggling. I had issues with the stock lightcolinsmx3 wrote:Thought you said you got the best ones?? Looks like quality control is lacking..... Mine don't wiggle!SuperK wrote:My projectors are kinda wobbly and not secure.... when the hood is up, I can take the light and wobble it back and forth... Anyone else's lights like this?
I dunno if you can see it, but the headlight doesn't sit right ever since I got the car...
I know it's been wrecked on the front before. I wanted to know if anyone else had the issue as well... but fowljesse says his are very tight. Meh.
- marcdh
Your frame may be a little out of alignment then? Are there any signs of distortion? Looks pretty minor though, maybe some carefully placed spacers or washers would sort it?
View Worklog
View Worklog
or the black bracket thing(cant think of wat its called) that holds your light up is broken. mines like that too. lookin at the pic the left corner of the lamp is popped out past the bumper, making it not flesh with it huh? if so u gotta replace the piece or glue or something. thats wat i can think of. correct me if im wrong.......
___________________
Black '92 GS [Project De-t Started!] [The spoiled one]
Green '95 1.6 [Daily][The jealous one...SOLD]
White '07 Mazda 3 GT [The pretty one]
[What can you say, I have a fetish for 3's]
mikeetown wrote: Do what you want to do dude cause in the end, your mx-3 is all about you.
- fowljesse
Well, it's not the fault of the projectors if you had the problem before you put them in.
I agree with Marcdh. If you can't fix the car, maybe you could modify the projector bracket.
- taylor_matt
SWEET! just received my lights today. SO special thanks to ray
And the packing job for mine was perfect
I will have them installed once my swap and paint job is complete (which will be soon hopefully)
Last saturday I've installed the new headlights
They're great, but I had a little problem:
the pins of the blue male plug ( connecting the headlight to the original electric plant) are a little different compared to original: they are too much thin and tight..so to have a correct contact I deform the female pins with a little screwdriver.
My car is an US-Spec car, originally with HB9004 lamps and same type of male plug..just like on the new headlight.
Anyone had the same problem?
Anyway the installing wasn't so difficult
Just another little note: the missing point of fixing to the frame in the peak of the headlight (near the 3 leds)..if it was present, the headlight would not be so shaky
Using high beams, the low beams are off, right? I'm thinking to connect the 2 supply wires with a diode from the high beam wire to the low beam wire. So when I use the high beam, I supply both high and low; when I use low beam, the diode don't allow the current to go to the high beam circuit.
What do you think about this?
where did you get your lights ray or ebay
___________________
Ray's group-buy here in the forum
- fowljesse
They're also talking about this on another thread. I'm really looking forward to a write-up, because I want to do it, too.albarsv wrote: Using high beams, the low beams are off, right? I'm thinking to connect the 2 supply wires with a diode from the high beam wire to the low beam wire. So when I use the high beam, I supply both high and low; when I use low beam, the diode don't allow the current to go to the high beam circuit.
my passengers side is doing the same thing i can move it up and down and the bracket isnt movingSuperK wrote:I know, it SUCKS, because I dunno what I have to do to fix it... it's the drivers side headlight that's wiggling. I had issues with the stock lightcolinsmx3 wrote:Thought you said you got the best ones?? Looks like quality control is lacking..... Mine don't wiggle!SuperK wrote:My projectors are kinda wobbly and not secure.... when the hood is up, I can take the light and wobble it back and forth... Anyone else's lights like this?
http://www.cardomain.com/id/smoke187" onclick="window.open(this.href);return false;
93 mx3 bp-t
93 protege lx
93 mx3 bp-t
93 protege lx
